max to AutoCad
PAWUK
I work for a small Exhibition design company, a recent addition to the design studio models in max . However he’s come across a problem when he exports to AutoCad the drawing opens up tessellated. Its something I came across years ago but because I do it the other way round model in cad and render in max it was a problem without a needed solution.
The jobs been won, now he has to produce the working drawings but the dwg import cant be used , when the elevations are hidden the majority of the tessellations remain.
I know there’s probably an easy fix but been self-trained in both max and cad I can’t give him a solution, any help would be much appreciated
I came to this problem also.
I read that you need to set in AutoCAD:
DISPSILH = 1
ISOLINES = 1
and use HIDE (not 3dHIDE) and plot hide.
But it didn't work for me the last time.
I gave the model a material with color the same as the layercolor
(material with 253 and layer color 253)
When I insert rendered frames from Max I set the IMAGEFRAME in ACAD to 2 (no plot)
But I quess I miss a setting that would make the process easier.
