tdma02 Posted May 31, 2007 Share Posted May 31, 2007 How do i get resonable rendertimes using Vray fur and light cache (or is that impossible?) Im just looking for basic advice on this matter Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted May 31, 2007 Share Posted May 31, 2007 How's your fur set up? Number of hairs per face is the easiest way to control the fur. Obviously higher numbers will lead to slower render times. Number of knots is also a big factor. Knots control the number of verticies along the shaft of the hair so doubling the number of knots doubles the number of faces you need to generate to create a single hair. An expert may correct me on this, but the light cache deals with the fur, the same way if deals with any other arrangement of polygons, so I'd say that if you're experiencing difficulties, you may have your fur set up awarkwardly. Link to comment Share on other sites More sharing options...
Nic H Posted May 31, 2007 Share Posted May 31, 2007 I find fur calculations to be quiet fast considering teh density needed to look good. Whats your emitter object set up like? How many faces? What distrribution method? Per area? Per face? Knots is another factor. maybe post up a screengrab? Link to comment Share on other sites More sharing options...
