RyanSpaulding Posted July 5, 2007 Share Posted July 5, 2007 Hey guys, I've decided to give it a run...lets see how MicroStation XM plays with Modo, shall we? This will be sort of a WIP project...may not go too fast as I dont have much time...but this Modo forum doesn't go fast either. I must note, I'm a huge Modo novice at this point. So, 1st thing's first. What doesn't work on import... The XM > DXF > Modo workflow is not spot on. Seems Modo likes solids or mesh objects...so you cant drop your mesh to individual triangles. Wont work. So use 'Deep Exploration' to accomplish the import. Export from XM to U3D and then open the U3D in Deep Exploration, save as an LWO file. Modo seems to play well with this format. Credit on this specific topic goes to Peter Fotadis. I do not have the CAD edition to see if the DGN importer works well or not...saving us a step. No biggie as my 43mb DGN came to 1.5mb in U3D format. I noticed each object comes in seperate...so each post can be selected, each wall that's not merged, ect. The tree is Layer > Object. It does not differentiate between colors on your level. If you want to seperate objects of selectability, use different levels...not one level with X number of colors. The camera from XM comes through, but I'm not sure if it works yet. Directional light (aka the solar light in XM) also comes over. Modo is a bit resource heavy...I've noticed significant slowdown in workflow. It'd be best to make only necessary levels visible. Import can also be a bit slow. I've had 1 crash due to moving geometry around. Another note, on 1st glance, I dont see any Import function. It may just be the OPEN command when it's not an LXO (luxology) file...but at this point, I tried to have my scene open and import a simple 3ds file...and it's hanging. So I'm not sure how to add items to the scene such as XFrog trees, 3D People, or 3d autos. Link to comment Share on other sites More sharing options...
F J Posted July 19, 2007 Share Posted July 19, 2007 hey, y jump into modo anyways? :X Link to comment Share on other sites More sharing options...
RyanSpaulding Posted July 23, 2007 Author Share Posted July 23, 2007 Speed, the look, quality, price, support. I'm continuing this in the Modo forum. Link to comment Share on other sites More sharing options...
RyanSpaulding Posted July 24, 2007 Author Share Posted July 24, 2007 Ok, I'll update here as well, but I've created a small site called MicroStation to Modo. i'll have more in depth and better formatted stuff here. It's specific to MicroStation, but a lot of the info is general for you Autodesk users. http://www.ryan-spaulding.com/cad_to_modo/ A WIP, but we, the arch viz crowd, need this. Link to comment Share on other sites More sharing options...
Kurt Posted October 23, 2007 Share Posted October 23, 2007 http://www.ryan-spaulding.com/cad_to_modo/ A WIP, but we, the arch viz crowd, need this. excellent, Ryan! Keep up the good work! I'm very impressed with Modo, and did even purchase a license once, but I never had the time to really learn more than very basic things. Link to comment Share on other sites More sharing options...
F J Posted October 26, 2007 Share Posted October 26, 2007 hey Ryan, i just bumped into this Modo course.. www.3dgarage.com/p-15-modo-301-signature-courseware.aspx if u still need any help that is.. Link to comment Share on other sites More sharing options...
