Andy Park Posted July 17, 2007 Share Posted July 17, 2007 Hi. I'm new to autocad and I am really struggling to create roofs for residential buildings. I know i can create a pline then extrude with a taper. however this is very simplified i need something for more complex roofs. i've searched the net and cgarchitect and most of the roof references talk about roof slabs?? I think is is ADT not Autocad (not sure though). Can someone point me in the right direction for a tutorial. i have roof plans, elevations and angles. p.s i downloaded roofbuilder tool. i can't get it to create the correct extrusions. This is the last thing i need to do to finish a project and it driving me crazy? Link to comment Share on other sites More sharing options...
vizwhiz Posted July 17, 2007 Share Posted July 17, 2007 can you load up an image of The roof plan(s)? one old-school Type Technique That i still use is set up The floor plan and extrude walls vertically from That draw lines away from The corners of The bldgs To locate The elevations place each Elevation in its corresponding location relating To The floor plan rotate by 90 degress so That it is standing up facing The bldg/floor plans Then you can Trace over The roof outline making a closed polyline and Then extrude (back Toward The bldg 3d model) and Then slice off The Roof planes where indicated by The OPPOSITE elevation just one Technique among others, you can also draw The roof pitch from The corners, fillet in The middle, close The polyline and extrude That makes a solid roof piece hope This isnt Too confusing. maybe post an image That might help get Things started Thanks randy Link to comment Share on other sites More sharing options...
Andy Park Posted July 18, 2007 Author Share Posted July 18, 2007 The first is the roof plan the second is the isometric of the building the roof is goin on. the current roof that is on it doesn't have an overhang so i need to change it. I made that one by drawing the profile extrude it back the boolean any needed slopes. dont want to have to do that again. Link to comment Share on other sites More sharing options...
PAWUK Posted July 18, 2007 Share Posted July 18, 2007 How accurate do you have to be, if not dead on why dont you just scale up the roof you have to give you the over hang Link to comment Share on other sites More sharing options...
Andy Park Posted July 18, 2007 Author Share Posted July 18, 2007 It doesn't have to be too accurate, it just for visualisation, so i guess i could scale it up but if i get another project that needs to be accurate then i'll hit same problem, rather learn how to do it properly. Link to comment Share on other sites More sharing options...
PAWUK Posted July 18, 2007 Share Posted July 18, 2007 Hi Andy Not been in the architectual side I can only sugest how i would do it in autocad. like randy I would use closed poly lines then extrude them back. For end angles you could taper faces. Or you could do as Ive shown on the attached and seperate your plan up into sections create blocks and face taper the sides ,this took me 30mins , some of the heights are wrong to your visual but didnt have any to go by, also needs cleaning up . You could combine both closed poly and plan seperation and extrude if you need more detail Link to comment Share on other sites More sharing options...
Andy Park Posted July 19, 2007 Author Share Posted July 19, 2007 Thanks to all for your replies, I ended up doing as pawuk suggested. I hate roofs. i really need to get this roof builder tool working, has anyone been used it? Link to comment Share on other sites More sharing options...
visualasylum Posted October 16, 2007 Share Posted October 16, 2007 This can be easily done in ADT or Autodesk Architecture. The roof tool is very powerfull, but you just need to learn the tips and tricks. This roof for instance is a matter of 10 - 15 min work, with everything, faceboard and even the girders, rafters, trusses and all. Don't have the time now, but I will make a tutorial for a roof soon and post this online. cheers, Link to comment Share on other sites More sharing options...
malevy Posted February 7, 2008 Share Posted February 7, 2008 Can files from ADT be imported into max ? I am looking for an easy way to make roofs for my models. What steps are needed after importing the ADT file into max ? This can be easily done in ADT or Autodesk Architecture. The roof tool is very powerfull, but you just need to learn the tips and tricks. This roof for instance is a matter of 10 - 15 min work, with everything, faceboard and even the girders, rafters, trusses and all. Don't have the time now, but I will make a tutorial for a roof soon and post this online. cheers, Link to comment Share on other sites More sharing options...
visualasylum Posted February 15, 2008 Share Posted February 15, 2008 yes, 3dsmax9 recognizes the girders and ADT stuff. Link to comment Share on other sites More sharing options...
Geoffc Posted March 12, 2008 Share Posted March 12, 2008 I will post a tutorial later, but this is how I've figured out how to do complex roof with the solid features now in acad. Basically, you draw the plines in plan from a roof plan. Then I extrude the pline 1" (it needs to be a solid for the next step, and this provides the sheathing/plywood of sorts. I then draw a line with the actual slope up from the midpoint of the perimeter of a roof section, extend it to the highest point of that roof section, the using the control-leftclick choose the point or midpoint of that solid and lift in the the Z direction up. Let me see if I can show a very quick screen shot, I know this sounds confusing. You do need a relatively accurate roof plan, or create one. Link to comment Share on other sites More sharing options...
Geoffc Posted March 12, 2008 Share Posted March 12, 2008 So here's some very quick screenshots. What is useful, is once you have one height established, such as the hip I'm showing, I can use it's peak to set the height of the adjacent roof portions I would model next. i.e., I wouldn't have to draw that 4:12 orange triangle slope that I showed in the screenshot. (4:12 is an example, use whatever your actual slope is). BTW, when you raise a portion of the roof solid that is a ridge line, not point, you would use the midpoint of the ridge, not do each side separately so you don't get a jacked up solid with multiple faces. Clear as mud? Link to comment Share on other sites More sharing options...
Alfonso Lee Posted March 13, 2008 Share Posted March 13, 2008 If you're doing this just for visualiztion, it takes about 3-5 mins. using just changing thickness & 3dface to complete. Hope that helps. Link to comment Share on other sites More sharing options...
Homemark Posted February 10, 2009 Share Posted February 10, 2009 :)hello my name is Markjohn from ph hmm I studying Basic autocad. Can I make friends here? hmm just pm or contact me Markjohn.Bedural@gmail.com thanks Link to comment Share on other sites More sharing options...
