Billabong Posted March 18, 2008 Share Posted March 18, 2008 Is anyone else having problems with Onyx not producing enough leaves. I have taken the leaf density to its maximum and still it looks like its malnourished. The first render has 3 onyx tress in. the on ein the bottom corner is the Ulmus Americanas and the on the left is that Salix something or other. the Ulmus came out great, but that Salix looks naked as does the other, I also attached a simple Pine . It only gives me 3 needles at the very tip of the branch. I contacted Onynx and they thought I meant the thickness, so now I'm waiting again to hear back from them. By the way this is on xp Pro 64 bit Link to comment Share on other sites More sharing options...
Claudio Branch Posted March 18, 2008 Share Posted March 18, 2008 Hey man, here is my Salix Babylonica 3 straight out of Tree Storm without any modification to the trees' geometry. I just proxied it prior to rendering. It is just above 50K polys. If you want it, I will send it to you... Link to comment Share on other sites More sharing options...
Billabong Posted March 18, 2008 Author Share Posted March 18, 2008 Thanks Claudio I ended up going with a willow in that spot, but can you do me a favor and render out the Pinus negra 2 from the confiers section and see if it looks like mine. I just want to make sure It's onyx screwing up over here Link to comment Share on other sites More sharing options...
Claudio Branch Posted March 18, 2008 Share Posted March 18, 2008 Here is your coat rack, I mean tree. This Branch is tired of trees...time to go zzzzzzzzzz. Link to comment Share on other sites More sharing options...
Billabong Posted March 18, 2008 Author Share Posted March 18, 2008 Ok thank you so much man, So it obviously isnt me, thats just a pityful loooking tree Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted March 18, 2008 Share Posted March 18, 2008 It's not to bad for a winter tree with no leaves. I love me some leafless trees. The structures are beautiful. At leasst IMO. Link to comment Share on other sites More sharing options...
Claudio Branch Posted March 18, 2008 Share Posted March 18, 2008 The structures are beautiful. I agree... Link to comment Share on other sites More sharing options...
bjornkn Posted March 18, 2008 Share Posted March 18, 2008 I have different experience with the Pinus Nigra. Attached is the top of a 12m Pinus Nigra rendered in LW, single light and no textures. It's around 400 kpolys. It looks quite different from the others? Link to comment Share on other sites More sharing options...
Claudio Branch Posted March 18, 2008 Share Posted March 18, 2008 It looks quite different from the others? Agree...it's the best looking so far in shape and volume. For some crazy reason the top of mine was mishapen... Link to comment Share on other sites More sharing options...
Billabong Posted March 18, 2008 Author Share Posted March 18, 2008 that one does look better, but it still looks a little naked to me Link to comment Share on other sites More sharing options...
silver4 Posted June 23, 2008 Share Posted June 23, 2008 That's problem no.1 for me regarding onyx.Very few leaves,even with the density at max-i hate to see those branches through the foliage-which is not real at all.I like the small leaves setting,not the big ones,not realistic enough. I'm looking at the real trees outside my house : FULL of small leaves,i can't see one branch,and that's the way i want my trees to look.I'm doing an aerial view of a residential building and my trees are just like some wire balls from 100m above-and i NEED them onyx or something 3D as i will animate the camera towards the ground level. I'm using acer and aesculus (broadleaf)-130k poly each,plates,PL branches,and for what? How do the guys at icubeviz are doing those uber trees?? hundreds of them...full of leaves Link to comment Share on other sites More sharing options...
WAcky Posted June 24, 2008 Share Posted June 24, 2008 You have to increase the amount of branches too. I know what you're talking about. You have to work your way down the tree adjusting each density until you get what you're looking for. Onyx trees either rendered in 2d or proxies is the way to go. Link to comment Share on other sites More sharing options...
SgWRX Posted June 25, 2008 Share Posted June 25, 2008 there's a needle thickness or diameter/size setting when you get into the adjustments. makes a huge difference on the conifers, although it can be over done. i did one with a needle setting of 5mm and it looked like a nice full real tree. i think there's a post in here where i have an example. Link to comment Share on other sites More sharing options...
SgWRX Posted June 25, 2008 Share Posted June 25, 2008 http://www.cgarchitect.com/vb/29619-onyx-colorado-spruce.html?=#post202439 Link to comment Share on other sites More sharing options...
