Craig Ramsay Posted January 28, 2003 Share Posted January 28, 2003 Ok guys, in starting a new project where all I have is an OS map in cad and a few photographs of buildings. My boss wants me to make a sort of mass model of the area around a new site. He wants to see roads, pavements and blocks representing houses, offices etc and he also wants to have the roads sloping/rising as they would do in real life How would you guys go about modeling something like this? (I am used to modeling on flat land) Any help would be grately apreciated Link to comment Share on other sites More sharing options...
dwright Posted January 28, 2003 Share Posted January 28, 2003 The best way to do that will be to get a sat. Image of the area, and possible GIS info on the terrain and then model the boxes out of that. Another way will be doing image-based models out of photographs but both require time and the know-how, and image based modeling is not easy. It sound to me that you need more info, or know were to get more info/public data. In my opinion, he is asking to much, you may need to inform him that there is lots of guess work involved with current data and he may not like that. luck! Link to comment Share on other sites More sharing options...
ingo Posted January 28, 2003 Share Posted January 28, 2003 It depends on what the modell will be used for, are there close-ups or only birdview pictures ? If your plan has some height lines you can at least build your terrain, but as David mentioned its a lot of guess work to get the buildings well done. As long as the buildings are just grey blocks i wouldn't take care to much about their size, as long as the overall look is ok. HTH Link to comment Share on other sites More sharing options...
@lkion O Posted January 28, 2003 Share Posted January 28, 2003 Hello Craig, i would suggest several things:1)First try the local city council and ask if they have available any survey maps from previous design works 2) try the library of your area , you will be amazed what you can find there!those countor maps are usually hidden somewere... 3)Talk to your boss and tell him that the procedure involves a percentage of innacuracy as the outcome will depend clearly on the info you will have available. May the radiosity be with you! ps:I dont see how the Satelite image would help- much- much on understanding the inclination of the site. It certainly can give some clues. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted January 28, 2003 Author Share Posted January 28, 2003 I don't need to have too much detail in the buildings it is more of a context model to show how the new building will look with these other blocks/buildings around it. I can guess the levels of the roads etc, what I was getting at was how would you guys actually go about modeling this? Should I start by modeling the roads, then pavement, then land in between? Poly modeling or lofts along splines??? Please help Craig Link to comment Share on other sites More sharing options...
@lkion O Posted January 28, 2003 Share Posted January 28, 2003 Well Craig, how would you start modelling a physical model? Maybe im wrong but i would start from the base and then the rest of the elements. I think if you imagine following the same procedure it might come handy. Link to comment Share on other sites More sharing options...
@lkion O Posted January 28, 2003 Share Posted January 28, 2003 What software will you use for the modelling? Link to comment Share on other sites More sharing options...
Craig Ramsay Posted January 28, 2003 Author Share Posted January 28, 2003 Im using max 5 I just think there must be an easier way to do the sweepng roads and pavements than model them all flat with polys then raise all the verticies up to the correct levels which woild take ages sigh Link to comment Share on other sites More sharing options...
ingo Posted January 29, 2003 Share Posted January 29, 2003 Simply start to draw all the height lines on their specific height, mostly you don't need all, and make a mesh for the terrain. Just take attention to the streets so you dont have to big height steps in there. And than cut out the streets material.... Thats it. Link to comment Share on other sites More sharing options...
