Derek Forreal Posted April 12, 2008 Share Posted April 12, 2008 probably a dumb question but here goes: i'm panning in perspective but the panning speed is really fast (e.g. i move the mouse a few mm but the model moves about 50m). i've checked the manual/forums but can't find a way to bring down the sensitivity - any suggestions? Link to comment Share on other sites More sharing options...
Exellite Posted April 13, 2008 Share Posted April 13, 2008 i find every now and then if you highlight what u want to zoom or pan around eg.. a specific vertex, then hit the Z button, it centres it and your pan will reset. I absolutely HATE the orbit/zoom/pan controls in the perspective viewport, I cant beleive they still haven't fixed them in 2008, I dont know about 2009. It's definitely the biggest annoyance in max for me. Oh yes, also check your units setup because that can affect it too. Link to comment Share on other sites More sharing options...
lambros Posted April 13, 2008 Share Posted April 13, 2008 right, zooming extents selected will reset the pan/arc rotate pivot and things will get under control. Max 2009 has some new on screen controls to facilitate things around, but to work efficiently maybe you should invest on a 3dconnexion thingy. This is not an advert, it just really helps at hard navigational times! Link to comment Share on other sites More sharing options...
alrawli Posted April 13, 2008 Share Posted April 13, 2008 Reseting with z and checking scale should get around alot of the problems with rotating viewports. I think the connexion thingy is great for navigating realtime environments but just cumbersome and not precise enough for efficient modelling and scene control. Link to comment Share on other sites More sharing options...
Derek Forreal Posted April 14, 2008 Author Share Posted April 14, 2008 thanks guys, resetting with the 'z' key did the trick (scale was good). over on cg talk i learned that the pan speed changes (can become too fast or too slow) because the 'virtual target' of the perspective camera gets too close to (or too far from) the camera itself - hence the need to reset... edit - the above explanation was a bit wrong. the below is copied from the reply i got on cgtalk: "It depends on where the virtual 'target' of your perspective view is, and its FOV, relative to your point of interest. Alt-Ctrl-MMB, Mousewheel, and Zoom seem to change the position of the target by different amounts. FOV doesn't change it. You can create cameras from your perspetcive views and have a look" Link to comment Share on other sites More sharing options...
