Hollis Posted May 1, 2008 Share Posted May 1, 2008 I'm looking for some tips on increasing the time for uploading files into 3DS Max. I received an Architectural model in .3ds form from the Architect and I got an error notice in 3DS Max when I went to import the file so I converted the .3ds to a .dwg file in Autocad. Then I tried to upload the dwg into 3ds max and it took a day to load. I know the architect added more detail and meshes to the model but does anyone know how to increase speed of uploading without sacrificing the design? OR do you know why the error happened with the .3ds file in the first place? Thanks! Link to comment Share on other sites More sharing options...
Brian Smith Posted May 1, 2008 Share Posted May 1, 2008 make sure you're not loading gobs of linework along with it...especially things like hatch patterns...it will bring the import to a grinding halt Link to comment Share on other sites More sharing options...
Hollis Posted May 1, 2008 Author Share Posted May 1, 2008 I have tryed to auto edge the geometry meshes once they are in Max but do you know how to purge the hatches in Autocad before the import into Max? Thanks! Link to comment Share on other sites More sharing options...
danb4026 Posted May 1, 2008 Share Posted May 1, 2008 Clean up the autocad file before importing in Max. Try using the Layer Freeze (layfrz) command to hide unecessary layers in Cad, including hatches and such. Sometimes its better to simply trace over lines drawings using a polyline in cad before importing aswell. If you get rid of any unnecesary line work and clean up the line work you are going to use in Max, it will make your workflow a lot easier and faster. Link to comment Share on other sites More sharing options...
