Electraglide Posted June 24, 2008 Share Posted June 24, 2008 Just stumbled across this forum. I've been working on a plug-in for Sketchup that gives realtime rendering of your models inside Sketchup (no exporting). It supports point and area light sources with normalmaps/specmaps and you can walk around with collision/gravity etc and it works with Sketchup's Scenes too. The idea is you can flick between modelling and realtime instantly. Its kinda, Newport for Sketchup! :-) Called "LightUp" and the website is light-up dot co dot uk (I don't seem to be allowed to include a web link..) Adam Link to comment Share on other sites More sharing options...
oluv Posted June 27, 2008 Share Posted June 27, 2008 sounds interesting. i don't use sketchup so i won't try this but i wanted to ask how you calculate the light, ambient occlusion and such... do you apply them as textures? you would need some additional unwrapped uv-coords. or is it some vertex-lighting? Link to comment Share on other sites More sharing options...
Electraglide Posted June 27, 2008 Author Share Posted June 27, 2008 oluv said: sounds interesting. i don't use sketchup so i won't try this but i wanted to ask how you calculate the light, ambient occlusion and such... do you apply them as textures? you would need some additional unwrapped uv-coords. or is it some vertex-lighting? Yes, it bakes the lighting. No its not vertex lit. Adam Link to comment Share on other sites More sharing options...
oluv Posted June 30, 2008 Share Posted June 30, 2008 i had a look at the youtube videos and the results are looking quite impressive, especially for sketchup. so when you say that the lighting is applied as a texture to all the objects, how is the unrwapping process handled? does it produce one single texture for all objects or one texture per object? also am i able to define resolution of the resulting lightmaps? will it produce bigger textures, the more faces i have or will the accuracy decline the bigger my models become? thanks again for your comments and best regards, olaf. Link to comment Share on other sites More sharing options...
Electraglide Posted June 30, 2008 Author Share Posted June 30, 2008 oluv said: i had a look at the youtube videos and the results are looking quite impressive, especially for sketchup. Ouch, faint praise there! Sketchup is doing something there that Maya/Max/SI etc just can't do.. oluv said: so when you say that the lighting is applied as a texture to all the objects, how is the unrwapping process handled? does it produce one single texture for all objects or one texture per object? also am i able to define resolution of the resulting lightmaps? will it produce bigger textures, the more faces i have or will the accuracy decline the bigger my models become? LightUp handles the processing and lighting. Its very flexible in controlling resolution; if you really need to sample lighting every 4.5cm, you can, or you can let LightUp figure something reasonable and modify it. It handles groups and components too. Adam Link to comment Share on other sites More sharing options...
bjornkn Posted June 30, 2008 Share Posted June 30, 2008 I think it looks great! But so far I have been waiting for several hours to get the confirmation mail after registering for downloading the demo... It says that an email has been sent, but so far it has nor arrived. Any idea what the price will be? Link to comment Share on other sites More sharing options...
Electraglide Posted June 30, 2008 Author Share Posted June 30, 2008 bjornkn said: I think it looks great! But so far I have been waiting for several hours to get the confirmation mail after registering for downloading the demo... It says that an email has been sent, but so far it has nor arrived. Any idea what the price will be? Check your spam filter. The email gets sent instantly so modulo pinging around the internet to your mail server, it will arrive within minutes. You could try whitelisting light-up dot co dot uk too. Adam Link to comment Share on other sites More sharing options...
bjornkn Posted June 30, 2008 Share Posted June 30, 2008 It was not in my spam folder or anywhere else. However, I managed to resend the reg info and get it to resend the activation mail. This time it arrived promptly Link to comment Share on other sites More sharing options...
mrcamper Posted July 1, 2008 Share Posted July 1, 2008 I tried your website and I get this: Parse error: syntax error, unexpected $end in /home/lightup/public_html/index.php on line 91 Link to comment Share on other sites More sharing options...
Electraglide Posted July 1, 2008 Author Share Posted July 1, 2008 mrcamper said: I tried your website and I get this: Parse error: syntax error, unexpected $end on line 91 We're on it. Thanks for the heads up. Adam Link to comment Share on other sites More sharing options...
