vizwhiz Posted June 26, 2008 Share Posted June 26, 2008 i finally got my quad core back from my son after 8.5 months (long story) and now The material editor hangs up and completely locks The program every Time when accessing most of The buttons which should bring up a new dialog box This is Totally buffalo-ing me got some work To do but can NOT add materials or do any renders any ideas on how To fix This hang-up would be greatly appreciated cant find The maxstart.ini or cui or whatever un-installed 4x cleaned registery and max9 folder per local instructions TIA randy Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 26, 2008 Share Posted June 26, 2008 so you did 4 clean re-installs, and you are still having max hang when you launch the material editor? ...and it is always the material editor? i think 3dsmax.ini is the file you are looking for. it is either in the root of your 3dsmax directory, or you need to search the my documents directory for it. if you have done a complete re-install, it could still be a problem because i don't think re-installs overwrite the files in my documents. anyway, do a search for it, and delete it. keep in mind, deleting it will reset all of the customization you have done to your configuration. Link to comment Share on other sites More sharing options...
