pwharton Posted June 27, 2008 Share Posted June 27, 2008 Attached is an Interior done in MAX with Mental Render. C&C welcomed. Link to comment Share on other sites More sharing options...
AJLynn Posted June 27, 2008 Share Posted June 27, 2008 That's nice, but the ceiling looks a bit too glossy and it could use more lighting. Also, compositionally it would probably have more drama if it were in thirds instead of split down the middle - symmetrical is like soooooo 20th century. Link to comment Share on other sites More sharing options...
pwharton Posted June 27, 2008 Author Share Posted June 27, 2008 I take you mean the hutch under the TV? It was something i grabed from an older project. I'll work with adding more lightng and taking the shine off the ceiling. Thanks! Link to comment Share on other sites More sharing options...
A.Mitov Posted June 29, 2008 Share Posted June 29, 2008 I think you should correct your lighting. That deep red contrasts a lot with the bright blue outdoor lighting. If it's because of interior lightsources it should be yellowish. I think the interior would benefit from more outdoor light though. Link to comment Share on other sites More sharing options...
SandmanNinja Posted June 29, 2008 Share Posted June 29, 2008 A sky portal would bring in some blue from your physical sky. i like your scene - very good. Link to comment Share on other sites More sharing options...
pwharton Posted June 29, 2008 Author Share Posted June 29, 2008 Thank you, This is where I am stuck, I have a sky portal at the exterior windows and 2 Photometric Lights set to the D50 Illuminant default settings in the room. I have taken the 2 interior lights off “use Global settings” to gain individual control of the light intensity for each light. But I am not getting the brightness on the interior I would like. I am thinking of replacing them with MR omni’s instead. Any thoughts on how to properly light this would help. Link to comment Share on other sites More sharing options...
sardesign Posted July 5, 2008 Share Posted July 5, 2008 not sure what a sky portal is... use a photometric area light at the window [the size or larger of the window opening] and have it point straight in. keep the spot light [or direct light] to act as the sun. turn on FG [final gather] and test. if it's still too dark, turn on GI [global illumination] and adjust the lights individually on the modification panels. UP the energy if the scene is too dark. be sure to keep photon levels down for testing and then turn them up for a final rendering Link to comment Share on other sites More sharing options...
SandmanNinja Posted July 5, 2008 Share Posted July 5, 2008 Hey... A Sky Portal is the 'new' way to bring light into an interior space. The 'old school' way would be to do exactly as you described - drag a photometric area light over the windows to have them simulate the light from outside. A Sky Portal is like a funnel, channeling the light from your mrSky into an area (presemably interior). Don't be afraid to crank the multiplier on the Sky Portals. Use the Light Lister (Tools -> Light Lister) to help manage/control your lights. Link to comment Share on other sites More sharing options...
birdman67 Posted July 5, 2008 Share Posted July 5, 2008 My approach would be to get the daylight coming in through the window correct first, i.e., turn off all other lights and get a nice balance of daylight to match your exterior view. The room will probably be pretty dark at this point. Then, work on supplemental interior lights to balance it out. Link to comment Share on other sites More sharing options...
pwharton Posted July 8, 2008 Author Share Posted July 8, 2008 Thanks for the replys, I was out of town for the holiday weekend but now I am back and back at it. I have played some more with the lights energy and changes some of the materials. Let me know what you think. I still may reset the lights and do a new lighting solution since i have played around with a lot of the settings for the lights and sun. Link to comment Share on other sites More sharing options...
skala67 Posted July 8, 2008 Share Posted July 8, 2008 looking much better. One of your flowers is defying gravity in the vase. keep up the good work. cheers, Link to comment Share on other sites More sharing options...
pwharton Posted July 8, 2008 Author Share Posted July 8, 2008 Woops! Great catch, I will fix it on the next pass. Thanks Link to comment Share on other sites More sharing options...
