fadi3d Posted July 12, 2008 Share Posted July 12, 2008 guys i was rendering a night version of my last post (in finished work sect) and all of a sudden every material i have is giving me the warning :material returned overbright or invalid color. i turned the lights down and F-number up the scene is now too dark and still all the warnings. a few minutes ago everything was rendering just fine Pls help i have to deliver this today Link to comment Share on other sites More sharing options...
kippu Posted July 12, 2008 Share Posted July 12, 2008 that warning message ,believe it or not , will do nothing harmful to the final image As far as i know Link to comment Share on other sites More sharing options...
fadi3d Posted July 12, 2008 Author Share Posted July 12, 2008 hi Kippu.well for me it did nightmares as it left splashes of Blue colors in my render Link to comment Share on other sites More sharing options...
Fran Posted July 12, 2008 Share Posted July 12, 2008 Did you change anything in the scene at all? Could you have accidentally moved anything so that a light is intersecting with geometry? Link to comment Share on other sites More sharing options...
fadi3d Posted July 12, 2008 Author Share Posted July 12, 2008 Hello Fran it seems i had a tv with the screen as a Vray lightmat and a Plane in frront of it also with a Vray light mat but with a higher Multiplier.they were separated by at least 10 Cm .after i had the weird artifacts and a few crashes (i hate how much Vray crashes) i deleted the plane and now i am rendering.i 'll be posting the results later tonight .it sure would be nice if u took a look meanwhile if someone had an explanation for this i'd be grateful. Ps i did this trick before with no Prob. thank u and take care. Link to comment Share on other sites More sharing options...
WAcky Posted July 13, 2008 Share Posted July 13, 2008 You didnt turn off exposure in the VRay cam did you? Link to comment Share on other sites More sharing options...
fadi3d Posted July 13, 2008 Author Share Posted July 13, 2008 Hi James .i don't think so i just turned The f-number down to 3 from 4. anyway it is finished now and i'll put it in the finished work forum i hope u guys check it out and give me ur thoughts. cheers Link to comment Share on other sites More sharing options...
BrianKitts Posted July 13, 2008 Share Posted July 13, 2008 I've always found the biggest culprit of over-bright materials to be if you have a standard material buried somewhere in your scene. A standard material with a high specular value can cause your error a lot of the time. It's always best to keep all vray materials in a vray scene. But sometimes when I merge in objects from an old scene I'll get a standard material that slips in. Open your material library, sort it by scene and see if you have any standards in there, then check and see how high the specular is set. Turning it down could help, but a better solution would be to convert it to a proper vray material. Another thing to keep in mind is just because you are changing your f-stop it doesn't really affect how the materials and light are calculated in the scene. So you aren't really darkening down the materials. You are just darkening down how the actual image is exposed in the viewport. Think of it this way.... if you were to shorten your shutter speed the sun's intensity isn't going to get any weaker, your camera just isn't exposing it's full brightness anymore. So in this case changing your camera settings probably isn't leading to the best solution of your problem. Link to comment Share on other sites More sharing options...
Nic H Posted July 13, 2008 Share Posted July 13, 2008 i always use the 'vray material converter 2.5' from scriptspot converts the whole scene over to vray mats with one click, very handy for when you inherit a old scene. Link to comment Share on other sites More sharing options...
fadi3d Posted July 13, 2008 Author Share Posted July 13, 2008 Dear Brian ur explanation is Impeccable yet simple to grasp quickly (i wish i had a teacher like u in school ) but i dought it's an issue of standard material as the warning was naming almost every object in the scene.99.9 of which i think are Vray mat. i think the problem was as i said to fran upper in the thread although i have no explanation why ???? anyway i posted the results and i'd be honored if u and nic would drop in a line or two and tell me what u think http://www.cgarchitect.com/vb/31263-night-shot-vray.html thank u guys ur the best regards Link to comment Share on other sites More sharing options...
