color bleeding
vijayanimo
hi to all friend,
"How can i stop color bleeding"
i have problem with this tutorial, ( by Martijn Dekker)
http://www.cg-files.com/VrayColorbleeding.html
in this tutorial, three techniques describes about color bleeding
but i am unable to understand Method 1.
to stop color bleeding between red floor and white walls,he used saturation setting but when i did it on my pc, it is not working working.when i change saturation value in GI,there is no effect on output.all setting is default on my pc.
please help me.
thanks.
look at the http://www.spot3d.com/vray/help/150SP1/vray_overridemtl.htm vray Override material. you can supply it with the material to use at rendertime (the normal red one) and a lower saturation material to use when calculating GI.
also you get better color bouncing when using some of the linear workflow stuff, but thats much too complex to explain, so i find it better to just suggest the override :) (Even to my other internal artists. heh.)
