Jtrudeau Posted September 11, 2008 Share Posted September 11, 2008 Hi Everyone, I have upgraded to 2009 design and am having problems with a pretty simply rendering. The second "pass" with the rendering leaves out areas and doesn't include the transparency info. I have attached an image to help things along. Thanks in advance Link to comment Share on other sites More sharing options...
thierrybauwens@inpix.be Posted September 11, 2008 Share Posted September 11, 2008 are you rendering through the network? You should check if the update has been done on the others computers, also for the plugins Link to comment Share on other sites More sharing options...
d4legend Posted September 11, 2008 Share Posted September 11, 2008 2009 design has alot of problems that take getting used to, you might come acrosssome crashing during rendering thta my biggest problem.its not as stable as previos releases. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted September 11, 2008 Share Posted September 11, 2008 It look like a DBR bucket problem involving coplanar geometry. Make sure there is no coplanar geometry, and that all paths are UNC mapped to textures on a network, or that the textures are sent with the bucket. Link to comment Share on other sites More sharing options...
Jtrudeau Posted September 11, 2008 Author Share Posted September 11, 2008 are you rendering through the network? I'm not rendering through a network. Just an average Dell machine. It look like a DBR bucket problem involving coplanar geometry. Make sure there is no coplanar geometry, and that all paths are UNC mapped to textures on a network, or that the textures are sent with the bucket. Homeless guy- I'm not familiar with what your talking about. so if you could explain further it ould help a lot. I have rendered many images on my laptop at home in Max 9 and never had this problem so I am suspicious it might be my machine but still doubt it. Thanks all. Link to comment Share on other sites More sharing options...
Jtrudeau Posted September 12, 2008 Author Share Posted September 12, 2008 Does anyone think it may be the material used for the water? Link to comment Share on other sites More sharing options...
Jtrudeau Posted September 12, 2008 Author Share Posted September 12, 2008 I tried a different material for the Water (Arch +Design) and got the same results. It only seems to effect the transparency of the top of the water. I'm starting to think its a hardware issue. PLease help, this is driving me crazy!! There's an attachment of the results with the Different material. - Justin Link to comment Share on other sites More sharing options...
Matt McDonald Posted September 12, 2008 Share Posted September 12, 2008 Ah, ah, ah...you're cross posting! Link to comment Share on other sites More sharing options...
Jtrudeau Posted September 12, 2008 Author Share Posted September 12, 2008 You got me, I am a horrible person. But will someone still help this extremely frustrating problem? I dont desrve to be black balled Link to comment Share on other sites More sharing options...
Jtrudeau Posted September 12, 2008 Author Share Posted September 12, 2008 YES!! Thanks Brian , you made me realize that my water surface was .25 inches thick rather than a plane so it was creating wierd light bounces,. Thanks again Link to comment Share on other sites More sharing options...
Argyll Posted September 13, 2008 Share Posted September 13, 2008 (edited) Why not (zip) attach your file so we can have a look? You shouldn't have any problems with Pro Water Material and the answer may be as simple as making sure you have the most up to date drivers for your graphics card. Pro water works really well if the depth of your water varies and you have caustics enabled. I've attached a file that uses Pro Water that may be of some assistance. Edited September 13, 2008 by Argyll Link to comment Share on other sites More sharing options...
