Lanni Posted May 17, 2002 Share Posted May 17, 2002 I need some help with supersampling a carpet texture. I'm get swirls or something, I'm currently using the Max 2.5 Star, which should I use to fix this; Adaptive Halton, Adaptive Uniform or Hammersley? And what settings for it should I use? Here's a pic to show what I mean. Link to comment Share on other sites More sharing options...
Wolf Posted May 18, 2002 Share Posted May 18, 2002 I am starting to like the filter Soften it takes away the Sharp edges that computer models always have, i use a setting of 3-4 sometimes. Link to comment Share on other sites More sharing options...
STRAT Posted May 18, 2002 Share Posted May 18, 2002 i was gonna suggest that too. if ss no works then try a render filter instead. also try SUMMED AREA filtering too instead of the standard, this is subtler and should help. Link to comment Share on other sites More sharing options...
Guest robert Posted July 10, 2002 Share Posted July 10, 2002 Originally posted by Lanni: I need some help with supersampling a carpet texture. I'm get swirls or something, I'm currently using the Max 2.5 Star, which should I use to fix this; Adaptive Halton, Adaptive Uniform or Hammersley? And what settings for it should I use? Here's a pic to show what I mean. I know you problem, this is a bug i reported to discreet several times. The bad thing is, they changed nothing in Max 5. The problem occures on high resolution surface rendered with a supersampler. Question do use field rendering? Anyhow, there are tasks when you should use different renders like VRay, Brazil etc... robert Link to comment Share on other sites More sharing options...
John Dollus Posted July 11, 2002 Share Posted July 11, 2002 Are you sure you are using summed filtering on the texture map instead of the defaul pyramidal? John D Link to comment Share on other sites More sharing options...
Lanni Posted July 11, 2002 Author Share Posted July 11, 2002 yes I', sure Link to comment Share on other sites More sharing options...
John Dollus Posted July 12, 2002 Share Posted July 12, 2002 Standard Max scanline renderer? non-fielded? John D Link to comment Share on other sites More sharing options...
