VRAY Tensile structure material problem
frodo_001
Hello:
I'm using the vray for sketchup version and want to make a render for a tensile structure.
The main problem I have had it's on making the material because the tensile structure fabric that I must simulate its a little beigge translucent one.
So after many days I finally could make a material using the 2 sided material option and unchecking the double sided box from the options, and obtained a very nice traslucency just like the one the fabric has when it's installed. it can be aprecciated on the building wall and the shadow.:D
But the shadows over the membrane where completly lost and appeared to be just plain color.:(
Can any one help me with this I've been trying any kind of combinations for the 2 sided material, from applying one material only to one of the sides and the other none, to using two materials one opaque and the other translucid.
I show you the result on the attached image
Cheers
Hello:
Cheers
how about a VRayOverrideMtl, fake your shadow color by placing a simple material with a colored refraction (don't forget to check "affect shadows" in the shadow slot of the overridemtl.
I'm over-doing it slightly in my example to exaggerate the color, but you get the idea.
Edited by BrianKitts
