illiopic Posted July 23, 2009 Share Posted July 23, 2009 I need to update 30 machines with 30+ ip addresses for DR. Is there an external file that Vray reads from that I could update, as opposed to going into the System rollout and entering each IP manually? Link to comment Share on other sites More sharing options...
illiopic Posted July 23, 2009 Author Share Posted July 23, 2009 I found the file: vray_dr.cfg Link to comment Share on other sites More sharing options...
Koper Posted July 23, 2009 Share Posted July 23, 2009 did it work? where did you find this file? Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted July 23, 2009 Share Posted July 23, 2009 plugcfg i believe Link to comment Share on other sites More sharing options...
illiopic Posted July 23, 2009 Author Share Posted July 23, 2009 Yes, it did work. Simply followed the pattern within the file (ip + boolean) for each ip. Then copied the config file to each machine on the network. ..\plugcfg\vray_dr.cfg Link to comment Share on other sites More sharing options...
Koper Posted July 23, 2009 Share Posted July 23, 2009 would it be possible to configure Rt so that it shows the computer name instead of the IP, and to see which IP's are active for use? That is one of the things I miss. You'll notice that when you look at the assigned IP adresses in RT that there are a couple of columns for this information already. maybe its just turned of somewhere in configuration. I'll see tmrw in the office. Thanx for sharing Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted July 24, 2009 Share Posted July 24, 2009 No there isn't unfortunately, it seems a very obvious and useful addition, but they never implemented it :| (And vlado said he would address the RT list not working with machine names in his next update probably.) Link to comment Share on other sites More sharing options...
