baily5 Posted August 24, 2009 Share Posted August 24, 2009 Hi, I was just curious if anyone would be able to help me, i'm trying to tile a stone wall similiar to the attached image but due to obvious problems such as the stones not lining up with one another at the edges i'm not sure how to get a clean seam for tiling on a large area such as a house wall. thanks Link to comment Share on other sites More sharing options...
WAcky Posted August 25, 2009 Share Posted August 25, 2009 You could use a photoshop plugin to generate a seamless texture but for textures like this i don't think it will work well. Another option is to use the offset tool in photoshop to help you create a tiling texture manually but this also might be a bit tough. Another option is to use a Bercon map seen here. I'm not sure how flexible it is as I've never used it. The other option I can suggest is to use StoneCad. There are lots of maps like yours in this small application that outputs tileable textures. I've heard that it doesn't work anymore so if thats the case I've attached the 3 that are closest to your original map. These maps are tileable. Link to comment Share on other sites More sharing options...
baily5 Posted August 25, 2009 Author Share Posted August 25, 2009 thanks for that, yeah i've tried the offset method in photoshop but it just doesnt give that polished result due to the fact that stones/bricks aren't symmetrical Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 25, 2009 Share Posted August 25, 2009 Time to brush up on your Photoshop skills. Craft in creating custom textures is vital to quality images. Link to comment Share on other sites More sharing options...
baily5 Posted August 25, 2009 Author Share Posted August 25, 2009 Agreed Link to comment Share on other sites More sharing options...
