BrianKitts Posted September 29, 2009 Share Posted September 29, 2009 Is it possible to replace or retarget existing clips in Premiere? I'm working on an animation that has two options and I want to setup the entire animation (transitions, effects, corrections etc...)with one set of frames, then once complete save it out then swap out the input files so I don't have to do the whole thing twice. It's easy with AE, you just use the "replace footage" option.... but I'm not finding something comprable for Premiere.... Link to comment Share on other sites More sharing options...
Chad Warner Posted September 29, 2009 Share Posted September 29, 2009 It's been awhile, but I'm pretty sure you can relink footage, normally if you right click on the footage in the assets window (or whatever it's called) you 'll see the options to locate the frames. The other alternative would be to simply move all of your old frames and replace them in the exact same spot with the same names and have premiere pick them up automatically. Link to comment Share on other sites More sharing options...
BrianKitts Posted September 29, 2009 Author Share Posted September 29, 2009 The other alternative would be to simply move all of your old frames and replace them in the exact same spot with the same names and have premiere pick them up automatically. That was my original workaround I've got two identical folder sets with all the segments in them, and I was going to rename the root so that Premiere couldn't find the files the next time I opened it, and then I'd manually relink them, but I thought it was worth seeking out the proper way. Link to comment Share on other sites More sharing options...
Justin Hunt Posted September 29, 2009 Share Posted September 29, 2009 one way I found was to import the new footage, select it in the bin and select the footage in the timeline. Right-click the timeline footage and say "Replace from bin" and it will swap the footage. jhv Link to comment Share on other sites More sharing options...
BrianKitts Posted September 29, 2009 Author Share Posted September 29, 2009 one way I found was to import the new footage, select it in the bin and select the footage in the timeline. Right-click the timeline footage and say "Replace from bin" and it will swap the footage. jhv Perfect... that works, thanks Link to comment Share on other sites More sharing options...
Justin Hunt Posted September 29, 2009 Share Posted September 29, 2009 did it keep the adjustments? jhv Link to comment Share on other sites More sharing options...
milfora Posted October 20, 2009 Share Posted October 20, 2009 You can also hold down 'ALT' and drag the new footage from the bin over the footage in the timeline to replace it. AM Link to comment Share on other sites More sharing options...
