iglightcache calculation taking ages to calculate...if i turn on dispalcement
chow choppe
hi everyone
i am working on an interior render.
I am doing test renders at very low settings and my lightcache is taking a lot of time to calculate and it almost hangs in the middle.
my lightcache settings are very low
200 subd's
0.02 sample size
no of passes 4
screen mode
my irradiance mode is set to hsph 20, inter samples 20 and m using custom -3,-3.
If i turn off the displacement in global switches then it calculates fine within 10 seconds . My all furniture is using displacement so i can't turn it off globally.
what is wrong with my settings?
can anyone suggest anything?
thanks
Edited by 3dsmaxed
spell check
As I understand it, that's the 'cost' of using displacement. It's modifying geometry each time you render, so it has to do a lot of math.
The Pro: It's easy on your viewport when modelling
The Con: It increases your render time
There may be some tricks that users with more experience in VRay know, but that's a general rule of thumb.
Everything has a cost. :)
