markf Posted November 2, 2009 Share Posted November 2, 2009 Is there a hot key that moves the selection up or down in the modifier stack? For instance an editable poly under a turbo smooth under a unwrap uvw. Is ther a hotkey that would allow one to move the selection between the different modifiers? I hope I'm being clear enough to understand here. I looked at the online hotkey map but didn't see anything. I have a vague memory of this being available but can't recall where I saw it. Link to comment Share on other sites More sharing options...
Donald2B Posted November 2, 2009 Share Posted November 2, 2009 Go into customize keyboard controls and there are two commands that you are interested in: Previous Modifier & Next Modifier Assign any shortcut key you like and you should be good to go. Link to comment Share on other sites More sharing options...
