Del Posted November 3, 2002 Share Posted November 3, 2002 hi, I'm trying to install on Windows 98 and get the AC1ST15.DLL required message. I know I have to change the autoexec.bat path but how? Do I just type c:\progr~1\common~\autode~1 in the file? I tried but can't make it work and looked on the Autodesk site and followed troubleshooting instructions. Can someone explain step by step what I should do please! Thanks for your help. Del Link to comment Share on other sites More sharing options...
Kerry Thompson Posted November 3, 2002 Share Posted November 3, 2002 Hi Del The line c:\progr~1\common~1\autode~1 has to be added to the path name as follows: Open up Explorer Right click on the file autoexec.bat, select edit Add the following line SET PATH=%PATH%;C:\PROGRA~1\COMMON~1\AUTODE~1 Save the file Restart the system and see if this works. You might also consider using Windows 2000 for the AutoCAD at some stage to improve stability and performance. Hope this works for you. Regards Kerry Thompson Link to comment Share on other sites More sharing options...
Del Posted November 4, 2002 Author Share Posted November 4, 2002 Hi Kerry Thank you for that advice, I still can't get it to work though. Guess I should try it with 2000 instead. By the way, I am a beginner and have seen week long courses with a City & Guilds exam at the end (4351-01) it costs £1000, is this a good idea to help me become a technician or am I better off learning from a book? Thank you again for any thoughts, I appreciate it so much as I have noone to ask and would like to learn enough to work in the industry eventually. Del Link to comment Share on other sites More sharing options...
