TSuess Posted November 5, 2009 Share Posted November 5, 2009 I have been racking my brain for weeks trying to figure this out. On occasion I would receive the following message when submitting my renders to backburner. "Task error: An unexpected exception has occured in the network renderer and it is terminating." Most files rendered fine. I had no idea why this was happening. I scoured the forums and found nothing. well I just figured it out. When I was rendering a scene from a camera which had the Camera Correction modifier on the submitted rendering would fail!! In conclusion: Backburner does not support the Camera Correction Modifier!! I am running Max Design 2009 x64. If anyone knows a work-around I would appreciated it. Link to comment Share on other sites More sharing options...
BrianKitts Posted November 6, 2009 Share Posted November 6, 2009 I've had issues in the past with the camera correction modifier when using standard cameras that were set to hidden when sent to backburner. Might be worth investigating if the camera being hidden or not is causing your issue. Link to comment Share on other sites More sharing options...
tayrona Posted November 6, 2009 Share Posted November 6, 2009 I have often used camara correction modifier and have never had troubles in BB... is the first time I hear about it.. Link to comment Share on other sites More sharing options...
TSuess Posted December 8, 2009 Author Share Posted December 8, 2009 Sorry all. I was wrong. My Backburner error had nothing to do with the Camera Modifier at all. I simply didn't have Max 2009 service pack 1 installed. Find it here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11384420&linkID=9241178 Link to comment Share on other sites More sharing options...
