pwrdesign Posted November 18, 2009 Share Posted November 18, 2009 Hi all! Having a problem that we've had since we started with Vray, a few months ago... First of this is some information: Model: DWG file attached as linked file Primary Bounces: Irradiance map, preset High Secondary bounces: Light Cache, subdivs 800, the rest default Lightening: Daylight system, Vray Sun as sun and mrSky as sky This is my result: You can see ugly shadows in between the buildings... Link to comment Share on other sites More sharing options...
WAcky Posted November 18, 2009 Share Posted November 18, 2009 Well for one thing I hope you mean you're using the vrayphysical sky and not the mrsky!! A few points; the high preset is overkill. You could get away with low at the moment. You might want to up the light cache samples to around 1500 but I think what you're talking about is the bounced light you're getting. This is always going to happen because you're using a white material and the light is being thrown off this surface quite easily and is staining the rest of the scene. There are many solutions but probably the quickest way is to turn down the secondary bounce multiplier which will help reduce this effect but will result in physically inaccurate lighting. Or another method is to use the VrayOverrideMtl. I reccomend looking at the examples here Link to comment Share on other sites More sharing options...
pwrdesign Posted November 18, 2009 Author Share Posted November 18, 2009 Thanks James! I'll give it a try! How do I choose vrayphysical sky when I create a Daylight System? As Skylight I only have IES Sky, Mr Sky and Skylight? Link to comment Share on other sites More sharing options...
WAcky Posted November 18, 2009 Share Posted November 18, 2009 Dont use a skylight in the daylight system. Set it to none or the equivalent. It should promt you to put on into the background. If not, go to your environment dialogue and stick a vrayphysicalsky into your background map slot. Link to comment Share on other sites More sharing options...
