bobaki Posted January 8, 2010 Share Posted January 8, 2010 This is my first attempt at this Arch Viz scene...this is just a WIP and i am only testing out the lighting and seeing how the props react with light.. I take no credit for the props i got it from a tutorial video and chucked it in to just make sure everything looks good.. The Focul length on the second render test was changed coz i made a mistake not changing it back. C&C is always welcome... Would be greatly appreciated Link to comment Share on other sites More sharing options...
redheadx Posted January 10, 2010 Share Posted January 10, 2010 Its coming along. The scale seems a bit off with the furniture compared to rest of the room. Scale them up a little more. The rug is a bit to thick. Are you using V-ray? If so a displacement modifier or V-ray fur would work great. Link to comment Share on other sites More sharing options...
munna51214 Posted January 10, 2010 Share Posted January 10, 2010 if this is ur start than good keep it up .light is not good cam,angle is not good.ok Link to comment Share on other sites More sharing options...
bobaki Posted January 10, 2010 Author Share Posted January 10, 2010 thank you...i will keep it up Link to comment Share on other sites More sharing options...
Jonathan Sanchez Posted January 10, 2010 Share Posted January 10, 2010 the scales of the furniture are off.. way too small. Also, remember that in a real environment.. there is not only light coming from that window...but from windows out of view behind the camera. Make sure to put some vray lights behind the scene to simulate natural light coming from other sources within the room. Link to comment Share on other sites More sharing options...
bobaki Posted January 11, 2010 Author Share Posted January 11, 2010 to redheadx..Yes you right, the furniture does look scaled negatively for the scene, as i went back to check it out the window was way too big for the furniture, i was like LOL. I am not using Vray, i am using Mental ray for the lighting including Global Illumination and Final Gather for getting rid of the splotchiness. To Sanchez, You are quite right that light does not come from one window but another window from behind of the camera, i should have put that into consideration when i tried to light the room but i neglected it, and no Sanchez i am not using Vray.. BTW can someone tell me what is the difference between Mental Ray and Vray, i have used Vray only once but not to the extent i have used mental ray, so if someone could explain i might give it a try.. Thank you all for feedbacks...i really really appreciate it . Link to comment Share on other sites More sharing options...
