Billabong Posted February 2, 2010 Share Posted February 2, 2010 I was wondering if anyone has found a fix or workaround for this yet. When rendering anything, My comp is pretty much useless. Ive got low thread priority ticked and I set the priority in the windows task manager to below normal.I also created that script in Ken Pinmental's blog, which doesn't help either I was just hoping that maybe someone found a workaround. Thanks for any input -B Link to comment Share on other sites More sharing options...
BrianKitts Posted February 3, 2010 Share Posted February 3, 2010 right click on the 3dsmax process in your task manager and select "set affinity" and turn off one of the processors. that will free it up to do other stuff while the rest of your cores crunch on max stuff. Link to comment Share on other sites More sharing options...
Billabong Posted February 3, 2010 Author Share Posted February 3, 2010 Thank you so much Brian -B Link to comment Share on other sites More sharing options...
amer abidi Posted February 3, 2010 Share Posted February 3, 2010 Yup, I always set one processor (of 8) free so i can continue working normally on my workstation while rendering. Link to comment Share on other sites More sharing options...
Jimy Posted February 3, 2010 Share Posted February 3, 2010 Yeah I do the same. Always run Max and/ or rendering at below normal priority and this frees up most things; apart from compositing software. I find that I too have to set affinity to minus 1 core to get Nuke to render even a single frame. The setting affinity is also great if you're in a render crunch and you can "donate" cores to the farm while you work, as general modeling etc only takes 1 core. You can also have 2 instances of Max running and split your cores between them (depending on your RAM). It's magic! Link to comment Share on other sites More sharing options...
