Can't create Panorama image (360) using Vray physical cam
cadviz
  cadviz said:
Thanx Brian for trying to help...
Unless I am not mistaken, seems to me the Thread has no relation with Vray Physical camera Panorama render...
Anyway I have to try it...
The thread tells you how to create a panoramic image using a vray, it can be done with any type camera, standard or in your case the physical camera.
Then it goes beyond that to detail the process of converting it to quicktime VR movie file.
  • 1 month later...
You can't use the camera overrides with the physical camera. For 360° panos you have to use either the Vray Dome Camera (which I could never figure out) or the standard camera. If it's too much of a pain to alter all your lighting multipliers maybe you could try rendering with standard cam and adjusting the exposure in the frame buffer? Might be worth a shot.
