danb4026 Posted March 24, 2010 Share Posted March 24, 2010 3ds vs. obj vs. Onyx 3D? Link to comment Share on other sites More sharing options...
uncle pritt Posted June 24, 2010 Share Posted June 24, 2010 Hi! The best is Treestorm that keeps the tree parametric, customizable and animable with the wind. I found useful importing it as an obj per part then convert it in mrproxy for a large distribution. The obj can export a higher number of polys than the 3ds. Bye! Link to comment Share on other sites More sharing options...
Shaun Hamm Posted June 24, 2010 Share Posted June 24, 2010 i like obj. You can export the obj file with multiple leaf id's so that that when you import it into max, you have a multi-sub material with however many different leaf variations you want. I take my leaf texture and vary the color value for each leaf slot. Link to comment Share on other sites More sharing options...
BrianKitts Posted June 24, 2010 Share Posted June 24, 2010 I have to agree with Shawn, obj, or 3ds is the way to go...... I would only use treestorm if you plan on animating the tree. Even if you have to change the tree later you can always use an instance replacement script. Treestorm creates multi/sub materials with a dozen extra (unused) slots.... quite annoying. When you export to file then import to max you get a nice clean muti/sub material. with just the 4 or 5 slots for the trunk and branches and however many leaf types you want. I typically build my trees and once they're done they get proxied and thrown in the library for later use, I can't remember the last time I even bothered with treestorm. Link to comment Share on other sites More sharing options...
Claudio Branch Posted June 24, 2010 Share Posted June 24, 2010 BrianKitts said: I can't remember the last time I even bothered with treestorm. I found that I didn't use it much either especially after I started using Advanced Painter. Did you ever get the wind to work? Link to comment Share on other sites More sharing options...
jkletzien Posted July 2, 2010 Share Posted July 2, 2010 I'll back Uncle Pritt in this discussion, Tree storm's ability to manage the number of faces in max, assign UVW's, make random seed variations of the base model, and of course animate wind makes it the best way IMHO. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 2, 2010 Share Posted July 2, 2010 I use TreeStorm. I have never tried any other method. Out of curiosity, can you import plates for the leaves with OBJ? Link to comment Share on other sites More sharing options...
Justin Hunt Posted July 2, 2010 Share Posted July 2, 2010 yes with control of the mesh detal and size Link to comment Share on other sites More sharing options...
