cmrhm Posted April 15, 2010 Share Posted April 15, 2010 I am very curiously regarding how to determine the rendering resolution based on the client's requriment for the presentation board size. Say I have 34"x22" presentation board, I need to render a site plan then PS in photoshop. I guess the min. resolution for PS is 150 dpi. calculation: 34"x150= 5100 11x150= 1650 So I need a rendering in 5100x1650? Does it mean I should have the same page size in photoshop? Link to comment Share on other sites More sharing options...
aaronrumple Posted April 15, 2010 Share Posted April 15, 2010 Thats the idea - except your math is off (you did 11" vertical - not 22") Link to comment Share on other sites More sharing options...
cmrhm Posted April 15, 2010 Author Share Posted April 15, 2010 Thats the idea - except your math is off (you did 11" vertical - not 22") Good catch, Aaron. is 150dpi good enough for printing? Link to comment Share on other sites More sharing options...
aaronrumple Posted April 15, 2010 Share Posted April 15, 2010 Good catch, Aaron. is 150dpi good enough for printing? Yes, for a DesignJet, it should be just fine. We'll even print lower for renderings to save time. We do 2D work in Photoshop at 200 DPI. Link to comment Share on other sites More sharing options...
Tommy L Posted April 15, 2010 Share Posted April 15, 2010 Industry standard (print industry) dictates 300dpi. However, I would aim for 150dpi rendering for print at 36x36. Checking with your client is only a good idea if you know your client well or if you are capable and willing to do 300dpi. Most clients will request 300dpi if you ask what they want. If fact, your client giving you an inch dimension without a dpi is kind of pointless. They are better off giving you an aspect ratio and saying 'we need it big'. With all the gadgets now available (strip rendering, pre-calced lighting, DR etc) size should really never be a problem for print. Its when you start needing HD in animation that it gets a bit squeaky bum time. Link to comment Share on other sites More sharing options...
cmrhm Posted April 15, 2010 Author Share Posted April 15, 2010 Industry standard (print industry) dictates 300dpi. However, I would aim for 150dpi rendering for print at 36x36. Checking with your client is only a good idea if you know your client well or if you are capable and willing to do 300dpi. Most clients will request 300dpi if you ask what they want. If fact, your client giving you an inch dimension without a dpi is kind of pointless. They are better off giving you an aspect ratio and saying 'we need it big'. With all the gadgets now available (strip rendering, pre-calced lighting, DR etc) size should really never be a problem for print. Its when you start needing HD in animation that it gets a bit squeaky bum time. Great inside tips on this issue. Thanks tommy. Link to comment Share on other sites More sharing options...
