nisus Posted August 30, 2002 Share Posted August 30, 2002 Hi all, Here is my problem: First I render a nice background - a groundplane, a basic city, a skydome and some haze - above which I want to compose the close-up views of a building/site. When I load the images in as background files and render the building/site above, the skydome pushes these images away i.e. it renders above the background. When I turn off the skydome this is correct but I don't have nice reflections of the sky in glass or watert parts. So... Does anyone knows how I can exclude an object from the alpha channel? Anyone has another tip? rgds nisus Link to comment Share on other sites More sharing options...
HeDaCoM Posted August 30, 2002 Share Posted August 30, 2002 hi. nisus with problems ? wow I don't understand your problem. exactly.. what do you mean ? pushes these images away ? Link to comment Share on other sites More sharing options...
nisus Posted August 30, 2002 Author Share Posted August 30, 2002 Hi hector, Basicly we have a background image onto which you add a kind-of cutout version from the building. To make that cutout we use the alpha channel so we have a clean seperation of the building BUT if we use a skydome, the seperation/border is not that of the building but of the skydome. Pretty useless... Got it? rgds nisus Link to comment Share on other sites More sharing options...
quizzy Posted August 30, 2002 Share Posted August 30, 2002 MAX4: the following works, skydome: properties: uncheck: visible to camera MAX3: Render without skydome, save mask, render with skydome and apply mask again.... You can ofcourse also animate the visibility for the skydome so you don't have to do all those things by hand... MAX3 buy MAX5 [ August 30, 2002, 09:29 AM: Message edited by: quizzy ] Link to comment Share on other sites More sharing options...
nisus Posted August 30, 2002 Author Share Posted August 30, 2002 jup 5 Link to comment Share on other sites More sharing options...
