molson Posted March 25, 2004 Share Posted March 25, 2004 I am currently working on some Lightscape tools using maxscript. At work we are making the transition from Lightscape to MAX. We have a huge Lightscape block library and want to be able to use them in Max. I have created the following scripts to help us out. These scripts are available as is and I am not resposible for any problems that may occur from using them. These scripts have been tested on 3dsmax 5 and 6. If you would like to use these tools as well you can download them from the following links: Lightscape Block Importer http://www3.telus.net/cgmolson/maxscripts.htm Installation: -instructions on my site Please read the About rollout on the interface for known Limitations. If there are ANY problems with the scripts please let me know so i can make them better. If you have any ideas for new Lightscape tools you would like to see please contact me and I'll see what I can do. Thanks Mark Olson to contact me please send me a private message through this forum or use the email address provided in the Interface. ---edited to fix URL Links--- ---edited April 4th updated Plugin--- ---edited April 5th added instructions--- ---edited Sept. 15 added new version--- Link to comment Share on other sites More sharing options...
Videha Posted March 29, 2004 Share Posted March 29, 2004 thank and thanks again i have been waiting for a Plugin for this for 4 years works great autodesk should have done this long long time ago my congrats and thanks Link to comment Share on other sites More sharing options...
chen3d Posted March 31, 2004 Share Posted March 31, 2004 very good can you let max export animation path to .la files for lightscape? thanks Link to comment Share on other sites More sharing options...
molson Posted April 5, 2004 Author Share Posted April 5, 2004 I have updated this plugin. It now will support Blend and Cutout materials. It is programmed better and mapping is improved. Compatibility is also improved when using older .blk files. There was also a problem with import blk files with blocks that had no entities in them. this has been fixed. glad you like it. I have wished for a plugin to do this for a long time as well. I started learing maxscript and thought that i could tackle this. Sorry Chen, The max camera path is a different animal than the lightscape .la file. Mark Link to comment Share on other sites More sharing options...
molson Posted April 5, 2004 Author Share Posted April 5, 2004 Hey Chen, I know that you can export sequencial Lightscape view files from Max. mark Link to comment Share on other sites More sharing options...
chen3d Posted April 8, 2004 Share Posted April 8, 2004 thanks:) yes,Max can export view files but you know one path maybe have 500views,god in lightscape,you have to add 500 views in rendering setup,hand will be crazy hehe thanks again BTW,if can let lightscape radiosity with 2 or more CUP.not lsray,my mean lsrad Link to comment Share on other sites More sharing options...
molson Posted September 16, 2004 Author Share Posted September 16, 2004 I have added version 1.1 of my blk importer script. It can now handle Lights. I also created a geomtery plugin so that you can import only one block out of the file at a time. It has been tested on Max 5 and 6 the link is still: http://www3.telus.net/cgmolson/maxscripts.htm Link to comment Share on other sites More sharing options...
Darkpaul Posted July 8, 2005 Share Posted July 8, 2005 sorry guys, the blk importer is great but it's possible to import also the photometric data associated with the block?? in what way?? thanx a lot.. Paul Link to comment Share on other sites More sharing options...
molson Posted July 8, 2005 Author Share Posted July 8, 2005 I'll look ionto this for you Link to comment Share on other sites More sharing options...
molson Posted July 8, 2005 Author Share Posted July 8, 2005 What version of Viz are you using.? Link to comment Share on other sites More sharing options...
seismograph Posted July 25, 2008 Share Posted July 25, 2008 max camera animation to la file: http://www.cgtechniques.com/goodies/ls_la_exporter.php Link to comment Share on other sites More sharing options...
