garethace Posted April 2, 2004 Share Posted April 2, 2004 I received this reply to a post of mine at http://www.aceshardware.com/forum.... Just thought that I should share it with you guys, for your entertainment/interest.... not a bad post by any standards, and it does raise a quite interesting point in relation to the environment.... I notice that environmental science is part of architecture curriculum more these days.... There is a company that claims to have a relatively efficient process for turning any organic waste into oil, natural gas, and other fuels. I heard about it on an episode of Techknowledge on the Science Channel tonight, but there doesn't seem to be too much information about it on the web. http://www.ecologicinvestor.com/news/readfullnews.asp?NewsID=358 They seem to be building, or have built a 20 million dollar facility, so hopefully it actually works and isn't environmentally harmful. If it does work, then it wouldn't matter if you burn the resulting fuels since it is a renewable resource. It would just be part of the cycle unlike oil from the ground which adds to the carbon dioxide and takes oxygen out of the atmosphere. There is still a need for hydrogen or electric vehicles though. In valleys like Los Angeles and Silicon Valley, not producing carbon dioxide, carbon monoxide, and other polutants would be usefull since it sticks around and causes smog. I have found that a persons level of environmental concern depends on where they live a lot. I grew up in Michigan, which is mostly flat, and has a low population. Polution just blows away. There is very little environmental concern. Most people drive gas guzzling vehicles and a lot of people just burn their trash and heat their house with wood. I remember one of my friends who is into high powered vehicles saying that you could just bash all of the stuff in a catalytic converter out for better exhaust flow. He would just put a piece of pipe on there if a catalytic converter wasn't required by law. They don't check to make sure that the catalytic converter is actually working though. He just rebuilt the engine in his truck with a bunch of aftermarket parts. It is a 390 (old, very large engine; used to be used in busses and such, I believe). He spent about $4000. He used an expensive aluminum head, aftermarket crank shaft, headers, aftermarket carburator, and various other parts. He was planning on driving it to work every day, about 32 miles there and back. It requires premium gas, and it may get 5 miles to the gallon or so, I don't really know. It would definately be under 10 miles to the gallon. Hopefully he has reconsidered with the higher gas prices. This wouldn't work in Silicon Valley. I believe it is illegal here to install wood burning fireplaces in new houses. In California, you also have to get a smog check for your car every year or two, to make sure it is putting out acceptable levels of polution. This means that your engine must be in good running condition. It can't be burning much oil. I know a lot of people driving cars back in Michigan that they have to add oil to all of the time. One of my friends here has an older car, and he had to have the engine rebuilt to get it to pass the smog check (it needed a rebuild anyway). A few years later he had to put a new catalytic converter on it to get it to pass. Just read through some of the other replies, some excellent points of views and slants coming into that thread. The prospect of a 'hydrogen economy' is mentioned amongst other things.... http://www.aceshardware.com/forum?read=115069973 Link to comment Share on other sites More sharing options...
