MAX6 MR Displacement Shader
William Alexander
Hey,
Great shader and displacement, beats the snot out of anything I have used.
The question/s, see attachement
*This is obvoiusly a mesh realted problem
*Apears to be view dependant, i.e. displacing toward camera or sampling based on poly face & view angle
*This is an extreme case, large aspect and high AA sampling (16/4)
? Is the MR tessalation/displacement view dependant and or object (vertices/ polys)
? Would one large poly eliminate the per poly face sampling
? Is edge visibility an issue
? Would a direction displacement sub map be worth the effort to create and use.
? Any technical explanation as to how MR & the displacement shader interprets the map and geometry. Grass displacement would be awsome, but with these types of issues it may look like a genetic seed farm's test field.
Thanks for any info
WDA
--Its Both. You can adjust the parameters thru the Render Tab of The render Dialog
--No, its not necessarily the case. You can even do a great displacement with even the lowest polygon count.
--Yes. Use the MR edge shader to elliminate this.
--Havent been successfull so far. But you can try it using the shaderlist.
--Too bad, discreet sucks at this when it comes to documentation. But there was a free video tutorial about this at evermotion.org
Hope this helps.
Btw, Grass in MR is great. IMO
