mrwolfy Posted June 10, 2010 Share Posted June 10, 2010 What is the proper work flow to get units synced between Maya and Sketchup? When I import a model to Maya, which was exported from Sketchup, the scale seems weird. When importing to sketchup template, using centimeters, then exporting/importing to Maya set up in centimeters, the object seems small in Maya. In Sketchup the chair measures .85 m, in Maya .85 units (units that should be centimeters?). So it is scaled by .10? Anyway, anyone who has the flow down, will you be so kind as to share the settings? Thanks for reading! Wolfy Link to comment Share on other sites More sharing options...
-MerlyN- Posted June 10, 2010 Share Posted June 10, 2010 If your object is .85m in Sketchup and Maya's set to centimeters it needs to be scaled up by 10 to 85 units, not down. Link to comment Share on other sites More sharing options...
