Christ1982 Posted August 4, 2010 Share Posted August 4, 2010 Hi, I know there are many threads on here dealing with the hair and fur modifier being used to create grass, but from what i can tell nothing has come up dealing with this problem! I have finally managed to get the grass to the correct length, not quite the correct density, but i know how to work on that, but the grass is not coming out the colour that i am selecting in the modifier... Obviously i want it to be green and it keeps coming out as nightmare black grass!! Anyone got any ideas? [ATTACH=CONFIG]38466[/ATTACH] Link to comment Share on other sites More sharing options...
Christ1982 Posted August 4, 2010 Author Share Posted August 4, 2010 as a follow up i have read various other forums/pages/posts that say that the problem could be with lighting or occlusion... attached is an image of what i have at the moment and the settings i am using in the material parameters...if anyone has any inklings at all what they think the problem is a push in the right direction would be greatly appreciated!! Chris.[ATTACH=CONFIG]38468[/ATTACH][ATTACH=CONFIG]38469[/ATTACH] Link to comment Share on other sites More sharing options...
Matt McDonald Posted August 4, 2010 Share Posted August 4, 2010 For what its worth, I think a lot of people are ditching the hair and fur for grass method because its just too troublesome for questionable results. Search around for proxy grass tutorials and I think you'll be end up with a workflow that is a little easier to adjust and looks great Link to comment Share on other sites More sharing options...
jinsley Posted August 4, 2010 Share Posted August 4, 2010 you can check out this thread... I start out with pflow, but near the end I start working with the hair and fur modifier... http://forums.cgarchitect.com/37505-grass-test-using-particle-flow-mr.html Link to comment Share on other sites More sharing options...
jinsley Posted August 4, 2010 Share Posted August 4, 2010 sorry... didn't read that right. Matt is right, start taking a look at proxies... I only use the hair and fur to make my proxies... Link to comment Share on other sites More sharing options...
Christ1982 Posted August 10, 2010 Author Share Posted August 10, 2010 Cheers for the advice guys, I will look into using proxies. One thing that I have struggled with is that all tutorials seem to place grass on either nice flat planes (built in 3ds) or slightly undulating planes (again, built in 3ds). I build my models in Microstation V8i amd then import them as dxf's into 3ds. Will the proxy method still work in this case? Thanks again, Chris. Link to comment Share on other sites More sharing options...
Kurt Posted August 26, 2010 Share Posted August 26, 2010 (edited) Why don't you just render the grass in Microstation using the Luxology engine? fur/grass with microstation Edited August 26, 2010 by Kurt Link to comment Share on other sites More sharing options...
jinsley Posted August 26, 2010 Share Posted August 26, 2010 Why don't you just render the grass in Microstation using the Luxology engine? fur/grass with microstation how large of a patch could you create with that Kurt? The grass looks really good! Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 26, 2010 Share Posted August 26, 2010 I have had this happen before. I think it might have something to do with how the hair geometry is being processed. Try mr Prim, and if that doesn't work, try buffer. Like I said though, I only think this may be a solution. Link to comment Share on other sites More sharing options...
Kurt Posted August 26, 2010 Share Posted August 26, 2010 how large of a patch could you create with that Kurt? The grass looks really good! You can enable adaptive sampling, this will reduce the amount of fur based on the distance from the camera. Then you should be able to render almost any size. grass covered island Link to comment Share on other sites More sharing options...
dande Posted August 27, 2010 Share Posted August 27, 2010 First of all I would bring the model in from MicroStation as a DWG. Because using DXF your more likely to have problems. DXF is an old format and MicroStations DWG converter is much better. You won't have any problem with proxies once the grass blades are 3DS Max objects. Then proxy the grass blades. You can use a script to scatter the proxies. Have a look at Jeff Pattons tutorial on the http://www.mrmaterials.com http://www.mrmaterials.com/jeffs-blog/101-mrproxy-grass.html Link to comment Share on other sites More sharing options...
