Revit in to Max Material Work flow ?
Sketchrender
Hi
I am vray user.
I have imported a Revit model in to Max and have set up cameras and daylight system.
All the glass is completely transparent and none reflective ( well a bit ) as default.
Do you generly add a fall off map when you have the model in or what is your work flow.
Thanks for the help.
I would prefer to use vray as i am under pressure but the scene convertor will not show the materials as they come in which is very important.
Phil
