Sketchrender Posted September 29, 2010 Share Posted September 29, 2010 Hi I am vray user. I have imported a Revit model in to Max and have set up cameras and daylight system. All the glass is completely transparent and none reflective ( well a bit ) as default. Do you generly add a fall off map when you have the model in or what is your work flow. Thanks for the help. I would prefer to use vray as i am under pressure but the scene convertor will not show the materials as they come in which is very important. Phil Link to comment Share on other sites More sharing options...
