ridz Posted January 20, 2011 Share Posted January 20, 2011 I'm using sketch up 7 and 8. In both version, I'm having strange problem when I render them in Vray or Kerkythea. Some grouped items are not rendered (means they does not exist at all!) or sometimes they are rendered without the texture i applied. Can any one say why this happens and how to get rid of it? Thanks. Link to comment Share on other sites More sharing options...
n3CRO Posted January 21, 2011 Share Posted January 21, 2011 maybe you have flipped normals, in skp as i recall u go by rightclick on face and reverse face Link to comment Share on other sites More sharing options...
ridz Posted January 21, 2011 Author Share Posted January 21, 2011 maybe you have flipped normals, in skp as i recall u go by rightclick on face and reverse face No, no such thing happened. Link to comment Share on other sites More sharing options...
n3CRO Posted January 21, 2011 Share Posted January 21, 2011 (edited) Sorry for short explanation. You can check all your faces where texture is not visible in render, by clicking right mouse button-entity info. First slot represents front/white faces and the second slot represents back/green ones. If texture is applied only in back slot, you can experience problems when rendering cuz your texture is then practically turned on back or reversed, so you have to make sure that your textures are applied in first/front slot. Best way is to texture model again correctly by applying just basic material in first and the second slot in entity info for all faces. Select all green faces and reverse them by clicking right mouse button on one of the selected green faces and click reverse faces. Now when all the faces are white, you can apply your textures. Hope it helps if this is the case. Cheers! Edited January 21, 2011 by n3CRO Link to comment Share on other sites More sharing options...
ridz Posted January 21, 2011 Author Share Posted January 21, 2011 Thnaks for your effort n3CRO. But this si not teh case actually. I have several furniture downloaded from the library. When I render, they are vanished! If I explode all the grouped and component elements, only then they are being rendered. I'm not getting why this is happening. Link to comment Share on other sites More sharing options...
n3CRO Posted January 21, 2011 Share Posted January 21, 2011 Maybe the models from library aren't well modeled or got too many polygons/faces so skp can't bear it. The best way would be to use them as reference and model them by yourself. From where did you download them? Link to comment Share on other sites More sharing options...
ridz Posted January 21, 2011 Author Share Posted January 21, 2011 Downloaded from Google's 3d warehouse. It also happens with other grouped elements created by me sometimes. SO i think the problem is not with the model, but may be in any settings.. I have tried two renderer..but no luck! Exploding a huge model takes long time and it becomes too hard to edit them later. Link to comment Share on other sites More sharing options...
n3CRO Posted January 21, 2011 Share Posted January 21, 2011 When grouping items and applying materials on groups, you must enter the group and then apply textures on faces, because if you select group and you are not in that group and you apply materials on it, it practically is not textured at all until you enter the selected group and apply materials. Link to comment Share on other sites More sharing options...
ridz Posted January 21, 2011 Author Share Posted January 21, 2011 Yup, that is what I did! Link to comment Share on other sites More sharing options...
n3CRO Posted January 21, 2011 Share Posted January 21, 2011 Did you try to download models at http://archive3d.net/? They are all in 3ds format so you can import them via file-import. Link to comment Share on other sites More sharing options...
ridz Posted January 21, 2011 Author Share Posted January 21, 2011 I didn't try their model. But I have to render my current model now. Its a interior design and I need to submit it tomorrow Moreover it faced this problem in other model too where everything was made by me but was grouped. I exploded everything then rendered it successfully. But I need a solution for this problem. So looking for it. Link to comment Share on other sites More sharing options...
