kbeck199 Posted January 25, 2011 Share Posted January 25, 2011 Hello all- I'm pretty new to animation is max and want to do a very specific thing but can't find any resources on how to do it. Here is my issue: I have a building that is made of a bunch of a objects. I want the animation to look as if these "parts" are exploded from a central point, not shattering each individual objects, but basically just moving there postion is a spherical pattern (think of an exploded detail of a steel connection but backwards) I feel there is WAY to many parts to do each individually, there has to be a script out there! thanks! I hope this makes sense! Link to comment Share on other sites More sharing options...
pand0r Posted January 25, 2011 Share Posted January 25, 2011 You could try using a bomb space warp. If you set the minimum fragment size high enough, you don't shatter the objects. Link to comment Share on other sites More sharing options...
epelj1 Posted January 25, 2011 Share Posted January 25, 2011 Not sure if this helps, the page used to show previews of the videos, but for some reason it isn't now. Anyway, if it doesn't show how to do exactly what you want, it might show an alternative? http://area.autodesk.com/blogs/louis/reveal_techniques_and_autodesk_university_in_las_vegas Link to comment Share on other sites More sharing options...
