Crazy Homeless Guy Posted August 13, 2004 Share Posted August 13, 2004 hola. this is for a NICU diagram i am working on. i am using Light Tracer, and 2 cone light for the setup. i want the floor and columns to go more white, they are kind of gray right now, but i am having a problem with the floor, walls, and columns 'blowing out' whe i adjust either my surface style to be more white, or if i add more light. does anyone know what causes the blow out areas, and how to control them. they only happen around where 2 surfaces meet at a sharp angle, so i am asuming it has to do with reflected light, but how do i adjust that? Link to comment Share on other sites More sharing options...
abicalho Posted August 13, 2004 Share Posted August 13, 2004 They look white to me, to be honest. White will never be white when lighting is involved. As for the extra light in the corners, does your material have Self-Illumination? Are you using more than 0 bounces? It seems to me that light is being "generated" when it hits the objests. Alexander Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 13, 2004 Author Share Posted August 13, 2004 no self illumination, no specular. not sure why it is doing it. it is not horrible the way it is, but the glowing bothers me. i know that it won't get completely white, i don't necessarily want that. the white looks dingy to me right now, and i don't want that. this is a diagram rendering, so i am not trying to make it look real, just a pleasing to the eye. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted August 13, 2004 Author Share Posted August 13, 2004 i do have more than 0 bounces, but i thought this reffered to how many times the light rays bounced. Link to comment Share on other sites More sharing options...
abicalho Posted August 13, 2004 Share Posted August 13, 2004 It's the bouncing that's causing that - the object is plain white, so it generates values > 1.0 in those areas. Also, is your spot a regular or photometric? I think the bounces are not decaying. Use Bounce = 1 at max, and you should get rid of those problems. Or reduce the Color Bleed or Object Mult values. Alexander Link to comment Share on other sites More sharing options...
