cesar_agp Posted September 6, 2011 Share Posted September 6, 2011 (edited) Hi, i'm new using vray for SU and i have a problem to see the IES lights in the render... I download several .ies samples from diferents web sites, I increment up to 50,000,000 the power, and still not working. I´m sure that the problem its simple but i cant fix it. kind regards Edited September 6, 2011 by cesar_agp Link to comment Share on other sites More sharing options...
M V Posted September 13, 2011 Share Posted September 13, 2011 Is the layer that the IES object is on, off? If so, make sure render off lights is turned on in your options. Also, try a value of 0, sometimes this uses the power level set in the IES file. Link to comment Share on other sites More sharing options...
M V Posted September 13, 2011 Share Posted September 13, 2011 Also, make sure the IES object isn't burried in your fixture. Link to comment Share on other sites More sharing options...
