zhopudey Posted January 7, 2012 Share Posted January 7, 2012 I have a max design 2012 file, of a mall interior which is giving me major problems. The file takes over half an hour to open/save, and is very slow to work with. I deleted everything in this file and saved it. The empty file is >250mb! I searched and found one solution which says delete the reactor cache. But since 2012 doesn't even have reactor, it is of no help to me. Now, even if i create a new box in this problem file, and save select it - the new file goes over 250mb. I can't even merge anything from this file into a new file. Any ideas? Link to comment Share on other sites More sharing options...
zhopudey Posted January 9, 2012 Author Share Posted January 9, 2012 Any suggestions as to where I can start troubleshooting? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 9, 2012 Share Posted January 9, 2012 It's likely that you need to clear out your note tracker. It generates extra crap for no reason at all from time to time and the problem is usually seen in file size an save times. I wish I had a link to give, but I don't. I know there are scripts out there that can help I just don't can't find the one I used right now. Sorry I can't be of great help, but maybe his will lead you to your solution. And if I find it I'll re-post with a link. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 9, 2012 Share Posted January 9, 2012 Ah. Here is one right here on cgarchitect: http://forums.cgarchitect.com/61106-long-saving-time-3ds-max.html Davistalexander posted the script text to correct. It's a motion mixer and note tracker thing. Good luck! Link to comment Share on other sites More sharing options...
kippu Posted January 9, 2012 Share Posted January 9, 2012 rohan , blame it on the computer and ask the company to get you a new machine ..... no idea though whatsoever! Link to comment Share on other sites More sharing options...
zhopudey Posted January 9, 2012 Author Share Posted January 9, 2012 This thing worked!!! run this script on listener to disable max motion manager t=trackviewnodes;n=t[#Max_MotionClip_Manager];deleteTrackViewController t n.controller and run this to clear memory gc() The 300mb file came down to 20mb! ) Thank you Corey for pointing me in the right direction. Link to comment Share on other sites More sharing options...
