adonrai Posted February 20, 2012 Share Posted February 20, 2012 Hello Experts How to convert a .PDF file to the DWG format? Anyone could give me some advices. Regards Adon Link to comment Share on other sites More sharing options...
k240 Posted February 20, 2012 Share Posted February 20, 2012 Hi Adon, In the past, I have used Adobe Illustrator. It does a pretty decent job. Just open the PDF and export as a dwg. Link to comment Share on other sites More sharing options...
alkyon Posted February 20, 2012 Share Posted February 20, 2012 Yeap same thing here.As long as the pdf is exported from cad.If it is a scanned pdf then you will have problems translating it to cad.But the process is the same Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 21, 2012 Share Posted February 21, 2012 If you are working in Max I prefer saving out as Illustrator v8 over exporting to DWG, and then importing the AI file directly into Max. Believe it or not Illustrator can actually make a nice tool to assist with modeling. Link to comment Share on other sites More sharing options...
postite Posted February 22, 2012 Share Posted February 22, 2012 If you are working in Max I prefer saving out as Illustrator v8 over exporting to DWG, and then importing the AI file directly into Max. Believe it or not Illustrator can actually make a nice tool to assist with modeling. Hi Travis, Can you give an example how to use Illustrator to assist with modelling ? Thx Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 22, 2012 Share Posted February 22, 2012 Hi Travis, Can you give an example how to use Illustrator to assist with modelling ? Thx It is simple. Illustrator is a vector based illustration program. It has the power to create bezeir and complex curves more elegantly and fluidly than what Max does. For example... If you are modeling an elaborate ornate handrail it might be easier to trace a photo using Illustrators vector tools than it would be to trace the same photo in Max. After you have it traced in Illustrator simply export as AI v8, and then import into Max and extrude the curves to create your geometry. I would not run out and buy Illustrator for this but if you have it on hand you might as well take advantage of its strengths. On the downside Illustrator does not function at real world scale. This means you will need to scale an object once you import it into Max. To do this I recommend you Google the 3 point scale script for Max. It is a nifty script that allows you to select points to scale similar to how you would a CAD application. Here link is to a handrail that would benefit from the initial line work being produced in Illustrator. http://steelworks-online.com/wp-content/uploads/2010/08/Residential-Ornamental-Pool-Handrail-Stair-Rail.jpg?9d7bd4 Link to comment Share on other sites More sharing options...
postite Posted February 22, 2012 Share Posted February 22, 2012 Thx for the tip Link to comment Share on other sites More sharing options...
kuldeepbisht Posted April 10, 2012 Share Posted April 10, 2012 Hello Experts How to convert a .PDF file to the DWG format? Anyone could give me some advices. have you tried to you autocad 2012 for the pdf to dwg conversion. I use this software and got it very useful. K Link to comment Share on other sites More sharing options...
