A VRay riddle...
maxwellmoriyama
A relatively simple model...
VRay 1.5 + Rhino 5 + preview settings + displacement on = stuck on "building light cache" forever
VRAY 1.5 + Rhino 5 - displacement = renders fine
VRAY 1 + Rhino 4 + displacement = renders fine (with the same exact settings as those used in VRay 1.5 + Rhino 5)
Any help? I thought VRay 1.5 with Rhino 5 was supposed to be super fast, and able to take advantage of my extra RAM (16GB) while Rhino 4 maxed out at 4 GB?
Thanks!
if you're not using vray proxies, it smells like a dynamic memory limit issue. You're displacement will want a lot of RAM.
I've not used vray for Rhino, but by default in max it's set to only 400mb. If you're running 16 GB of ram I would up this setting to somewhere in the 12000 range.
