koncaliev Posted March 14, 2012 Share Posted March 14, 2012 Environment Background Visible through vray objects, i tried everything but noting worked. I use vray 2.0 and 3ds max 2010 Thank you! Link to comment Share on other sites More sharing options...
erickdt Posted March 14, 2012 Share Posted March 14, 2012 Your environment map is set to screen. Drag the map into the material editor and switch its mapping to spherical environment. E Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 sory i tried this, no effect Link to comment Share on other sites More sharing options...
erickdt Posted March 14, 2012 Share Posted March 14, 2012 Where did you change it? In the VRay environment rollout under "Reflection/Refraction Environment Over-ride" or in the MAX environment window? You want to change it in the VRay environment tab. Sorry, I should have been more clear. E Link to comment Share on other sites More sharing options...
Devin Johnston Posted March 14, 2012 Share Posted March 14, 2012 I don't think your seeing through the object, it looks like a reflection of the other side of the scene to me. Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 (edited) here are my setings: I think that there are the reflections + the problem of background visible through vray objects Edited March 14, 2012 by koncaliev Link to comment Share on other sites More sharing options...
Devin Johnston Posted March 14, 2012 Share Posted March 14, 2012 What does the whole background JPEG look like? Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 the last picture on the right Link to comment Share on other sites More sharing options...
Devin Johnston Posted March 14, 2012 Share Posted March 14, 2012 Ok well that's why it looks like you're seeing through it because all the scene has to reflect is that picture. I thought it was a 360 degree image since you were using spherical mapping but it's just a regular image and so your object is just reflecting what it sees. I hope that makes since. Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 here is another render but with diferent map for reflection and the same problem i think Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 the left one is for reflection and is set to be spherical Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 the same problem but now the reflection map is hdr mirrored bal Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 maybe you can try to render a simple scene like this and post the results with the settings Link to comment Share on other sites More sharing options...
Devin Johnston Posted March 14, 2012 Share Posted March 14, 2012 Since you have a map in the reflection override slot your material is reflecting whatever that map is, when you set the same map as your background it make it appear as though your material is transparent when it really isn't. Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 well, what are the best settings for rendering an object on a photo in vray and 3ds max? Thank you so much! Link to comment Share on other sites More sharing options...
koncaliev Posted March 14, 2012 Author Share Posted March 14, 2012 but my environment map is diferent now from the reflection map and yet the problem is here. is this a bug or i am too stupid to solve the problem whit this? Link to comment Share on other sites More sharing options...
frog_a_lot Posted March 14, 2012 Share Posted March 14, 2012 Try this.. Drag your environment background into your "Vray enviroment and reflection" slots in vray. Press '8' or open up your environment menu, turn off "use map" It is seeing your environment map as a refraction map as well, Link to comment Share on other sites More sharing options...
rebekahkim Posted March 15, 2012 Share Posted March 15, 2012 Hi! Can you do the same with all pictures? I mean to show them through vray objects? ___________________________ audio editor http://audioeditorfree.com/ Link to comment Share on other sites More sharing options...
Boris Horosavin Posted March 15, 2012 Share Posted March 15, 2012 What is IOR value for material? Try changing it to 1,01. Link to comment Share on other sites More sharing options...
koncaliev Posted March 15, 2012 Author Share Posted March 15, 2012 i tried but nothing changed, the problem is stil here Link to comment Share on other sites More sharing options...
koncaliev Posted March 15, 2012 Author Share Posted March 15, 2012 the problem is that the map needs to be active in environment menu Link to comment Share on other sites More sharing options...
Tommy L Posted March 15, 2012 Share Posted March 15, 2012 you cant use a photograph like that as an environment. you need to use a 360 degree capture. Link to comment Share on other sites More sharing options...
frog_a_lot Posted March 16, 2012 Share Posted March 16, 2012 Try this.. Drag your environment background into your "Vray enviroment and reflection" slots in vray. Press '8' or open up your environment menu, turn off "use map" It is seeing your environment map as a refraction map as well, Did you try what i mentioned? Link to comment Share on other sites More sharing options...
koncaliev Posted March 16, 2012 Author Share Posted March 16, 2012 yes, but no efect Link to comment Share on other sites More sharing options...
