jair_gh Posted May 12, 2012 Share Posted May 12, 2012 Hello. I'd like to ask you if you know, or if is there any way in 3ds max to obtain the splines on the centers of these cylinders, I mean, one spline on the center of each one. I know the create shape from edges technique, but I am looking for something that allow me create the spline on the core of the geometry. Let's suppose we have one million of these cylinders, and, in order to save polygons we want convert them to rendereable splines. How could I do that? I hope I make myself clear. Thanks. [ATTACH]47582[/ATTACH] Link to comment Share on other sites More sharing options...
datacrasher Posted May 12, 2012 Share Posted May 12, 2012 If you create a cylinder then use the align tool this will make the spline in the middle of your cylinder. you cannot covert a cylinder down to an editable spline it's just not possible because a cylinder in 3d and the spline is 2d you convert it down to a 3d object Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted May 14, 2012 Share Posted May 14, 2012 Nothing is coming to mind for a UI based approach. If your model is sufficiently like your example, then it should be possible for a script to do the job. It does look like your end caps are not perpendicular to the length of the cylinder; I don't think that can be accomplished with renderable splines. Link to comment Share on other sites More sharing options...
jair_gh Posted May 14, 2012 Author Share Posted May 14, 2012 It wouldn't matter really, I thought on the possibility when I saw a model of OnyxBroadleaf, because certain parts could be splines in order to save a lot of polygons, but there is not a way to do that on the Onyx app. Link to comment Share on other sites More sharing options...
fugglyknuckles Posted May 7, 2013 Share Posted May 7, 2013 I know this thread is a year old, but just for reference, you can do this with this script... http://www.scriptspot.com/3ds-max/scripts/spline-in-middle hope it helps Link to comment Share on other sites More sharing options...
