Daniel Doerksen Posted June 1, 2012 Share Posted June 1, 2012 (edited) ive noticed recently that there has been a few people saying that vray light portals are not needed, if your scene is setup properly. i just wanted to get a larger opinion on the matter. How many of you are rendering interiors with portals How many of you are rendering without? and how are your render times being affected vs your quality result? Edited June 1, 2012 by Daniel Doerksen Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted June 1, 2012 Share Posted June 1, 2012 I do interiors often and have never found the use. They in fact, often make things overly bright in my opinion. Get a good camera setting and put a very normal amount of lights in your scene (by normal I mean what would exist in the physical world), setup your glass to affect all channels and shadows so the sunlight finds its way into your scene, and I typically override the environment GI with a Vray sky map. This is all just my opinion. I don't see them here around the studio either, but when I started about a year ago they were common place. I don't know what caused the change, but.... it did. Link to comment Share on other sites More sharing options...
salvador Posted July 3, 2012 Share Posted July 3, 2012 Portals only take the color from what's behind. I understand it as transporting light info (colors, intensity, etc) into the lit geometry. With a VRay Sky overall, portals or not wouldn't make any difference. (I'm tlaking about VRay plane lights on windows) Link to comment Share on other sites More sharing options...
Nic H Posted July 3, 2012 Share Posted July 3, 2012 never used them Link to comment Share on other sites More sharing options...
CliveG Posted July 4, 2012 Share Posted July 4, 2012 +1 Never used 'em Might it be that before Gamma 2.2 LWF practices were commonplace that portals were necessary to drive light deeper into the interior scene and now that more people are running LWF that light naturally travels further into interior scenes? Link to comment Share on other sites More sharing options...
Braiz Posted July 6, 2012 Share Posted July 6, 2012 Hmm... We actually use portals at work, thus we don't use linear workflow... I personally use them on personal projekts, together with linear WF, BUT, implementing portals depends on the scene... Using portals will help drive light/color information into a your interior, but at the expense of severe noise.. On the other hand, you'll get better GI distribution and thus you can do with lower GI settings. So it's all about pros/cons I guess... Link to comment Share on other sites More sharing options...
Mrigank sarkar Posted December 20, 2022 Share Posted December 20, 2022 Sir pls can anyone help me with this vray information..i am looking for a skylight portal option in vray 5 3ds max there used to be an option for skylight portal in vray in the old versions have they removed that option in the new versions?.. if not where can I find them. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted January 2, 2023 Share Posted January 2, 2023 https://www.chaos.com/blog/v-ray-first-look-smarter-rendering-with-the-new-adaptive-dome-light "With the Adaptive Dome Light, Skylight Portals are no longer needed. It automatically figures out which portions of the environment to sample and which ones to ignore. This makes it much easier to set up and much more efficient." Link to comment Share on other sites More sharing options...
