whale Posted June 3, 2012 Share Posted June 3, 2012 He guys,, any suggestions on a good modelling workflow to create these kind of forms? Link to comment Share on other sites More sharing options...
jsf Posted June 3, 2012 Share Posted June 3, 2012 scriptspot.com has info for a commercial plugin called PARA 3D. I haven't used it so I can't recommend it, but this could be a good starting point for your research into how to create this kind of geometry. Link to comment Share on other sites More sharing options...
whale Posted June 3, 2012 Author Share Posted June 3, 2012 I will check it out right now.. Thanks.. I will let you know how it goes. Link to comment Share on other sites More sharing options...
mohamedjameel Posted June 3, 2012 Share Posted June 3, 2012 this might sound abit useless to u but i kinda tried it , well 1st thing u model this shape using loft and make 2 models of this shape , one is slightly bigger than the other (larger equal to the thickness of the board or metal used . then use either Para 3D (best choice or use a simple cut map (low resolution u can use it for far renders ) hope this helps Link to comment Share on other sites More sharing options...
MrCAD Posted June 12, 2012 Share Posted June 12, 2012 I would use loft too with multiple shape sections...that would be the best way out without plugins Link to comment Share on other sites More sharing options...
Simon Moir Posted June 14, 2012 Share Posted June 14, 2012 If it's just a prop you could do it very quickly with a surface deform modifier perhaps: Link to comment Share on other sites More sharing options...
