djoshi Posted June 11, 2012 Share Posted June 11, 2012 Hi, How to create realistic looking sky refection on bldg glass facade in mental ray using daylight system(Or any other way?). I am searching on net for tutorial but no luck??? Please help... Thanks.. Link to comment Share on other sites More sharing options...
ironwind Posted June 11, 2012 Share Posted June 11, 2012 As a start try out one of the "Arch & Design" preset materials for glass. (Templates ---> Select a template) Don't forget to use "solid" or "Thin walled" depending on how you glass is modelled. (Advanced rendering options ---> Advanced reflectivity options) Reflection strengh depends on the angle (camera vs. glass surface) but you can fake it if you want to under BRDF ---> Custom reflectivity function Glass is not flat, a SLIGHT (like 0,05) bump map will add realism by breaking up the reflection, make sure that the map is quite large and soft (like the procedural noice). A pure MR sky is a blue gradient (rather boring) adding clouds/background will make the reflections more interesting. My 0,05$ Link to comment Share on other sites More sharing options...
djoshi Posted June 11, 2012 Author Share Posted June 11, 2012 Thanks ironwnd..yes I know how to create glass material & all...My problem is to get good refection on it. When we add any cloud bg image in mr sky it becomes very unrealistic I mean map gets stretched etc. I get good refection in Vray when I put plan in front of gls with self illumination, but i cant use this technique in MR, as 1) MR sun does not have exclude option 2) I cant get proper self illumination object due to exposure control settings are for day light. I don't know how to use hdr in environment to get good results, tried couple of but not getting great results. So is there any way or other where we can get the great results..??? Is there only daylight system for mr day exterior render? is there other way to rig exterior light in mr where we would have some more control like exclude etc.?? Link to comment Share on other sites More sharing options...
djoshi Posted June 18, 2012 Author Share Posted June 18, 2012 Guys..please anyone?? Link to comment Share on other sites More sharing options...
Tommy L Posted June 18, 2012 Share Posted June 18, 2012 Im guessing your facade is curved....in that case then it will indeed stretch your reflections. If you post an image its much easier to give advice. Link to comment Share on other sites More sharing options...
