thomthom Posted July 5, 2012 Share Posted July 5, 2012 I was exporting some XFrog trees into mrProxy. The original model was scale up to match real size after importing. But I find the proxies comes in with the size of the original geometry before it was scaled. When I select the original geometry and activate the Scale tool it does say 519 So, how would I "apply" or bake the transformation so it recognized the scaled geometry as the correct and default size? (3DS Max 2013 Design) Link to comment Share on other sites More sharing options...
Tommy L Posted July 5, 2012 Share Posted July 5, 2012 You can apply an Xform then collapse back to mesh. However, you have two better ways of scaling up the original geometry. 1: scale at sub-object level 2: bind to dummy and scale the dummy as a controller. In both these options the object otself still sees itself as 100%. Link to comment Share on other sites More sharing options...
thomthom Posted July 6, 2012 Author Share Posted July 6, 2012 I see. Thanks for those tips. But there is no way of baking a transformation into the geometry itself? Like in SketchUp when you right click a scaled instance and choose "Scale Definition"? Link to comment Share on other sites More sharing options...
Tommy L Posted July 6, 2012 Share Posted July 6, 2012 Yes, that's what reset xform does. You'll find it in the utilities. Link to comment Share on other sites More sharing options...
